Arion Stereo Chorus Replacement/Clone
So I love my Arion, but it pops, it's not built very well, there's a volume drop...
Has anyone cloned or improved on the circuit? There's obviously loads of Boss and MXR chorus derivatives about and I wondered whether someone had taken on the Arion given its fame with Clapton/Landau.
Any suggestions on a chorus that gives the same lovely tones as the Arion would be appreciated...
  • Good question, I would like to know too.
    I have been back and forth between the SCH-1 and the MXR Analog  several times, settling on the MXR for size, bypass and mix / tone controls but it does lack some of the vibey / chewy character of the Arion and I still hope to find something that combines the best of both.
    This is the truth from hillbilly guitars!
  • You could probably rehouse and put a new switch on it and mod it for the volume drop.
    Or perhaps see if somebody could do it for you?
    A rehousing will be troublesome on this pedal. Everything is board mounted - including the in and out jacks - and so it could potentially be a risky job.
  • Probably doesn't help but they modelled it for the Helix and it is *really* close
    Andertons used to sell a modded one for silly money
    I love them too I've had a few over the years
  • Get a Boss LS-2 and put the Arion chorus in its loop (with volume boost) maybe?
  • I have considered putting the Arion in a loop and blending and also rehousing but it's a big PCB. Ideally I would just like to keep things small and simple with a compact pedal that gets closer. Maybe and Analogman mini with a blend option? It all gets a bit expensive trying different boot eek! options though when they don't work out. I had high hopes for the Callisto for example but it was an icy cold sounding thing
  • ESBlondeESBlonde Frets: 3591
    The big problem i have with my Arion pedal is the jack sockets. once they get worn a little they pop and cause signal loss. They are difficult to replace because they are board mounted so I bought a spare pedal, then another. Great sound, putting it in a loop might help but just being on my board a few years is enough to give problems. Hard wired might be an alternative in a permanant installation on the board.
    I have a Boss ES-5 loop switcher; when I engage the loop with the Arion in, it pops ;)
  • 57Deluxe57Deluxe Frets: 7339
    the NuX does...
    <Vintage BOSS Upgrades>
  • I would never have considered one of those, I mean its really cheap right? ;-)
    In some of the demos it does sound richer than the MXR and it has that all important for me blend control
    Thanks
  • So I love my Arion, but it pops, it's not built very well, there's a volume drop...
    Landau now uses the Way Huge Blue Hippo for his chorus sounds, you might be able to pick one of them up if it's a Landau sound you're after.
