I see images of various pickup wiring looms for 335 semi-acoustics and the like, using vintage style waxed cloth single core wire that has the exposed braided screen - earth connections are neatly made by soldering the outer screen to the back of the pots as the wire passes over. Anyhow, I'm making a loom for an Ibanez semi-acoustic guitar (in readiness for some of
@TheGuitarWeasel's fine pickups) and would like to use the same technique. So basically any tips for how to best do things? I have done a lot of guitar wiring/soldering in the past, but haven't used this approach before. Cheers!
