Fx not working with acoustic?
I used to use a wah pedal during solo acoustic sets but recently the effect has been much less pronounced - to the point it's almost no change at all. I've also noticed the same problem with my TC Sub n Up pedal.
Both work perfectly with an electric and I'm sure they used to work fine with the acoustic but I'm stuck as to why they don't now.
Any ideas?
  • prowlaprowla Frets: 4929
    Does the acoustic have a pickup?
  • Yeah it's a shadow preamp with piezo pickup.
  • ICBMICBM Frets: 72442
    Battery going down in the preamp?
    Drastic EQ setting on the preamp EQ in order to offset the shitty sound of it? ;)
  • I did wonder about the battery, I change it fairly regularly as I get a load from work but I can't remember if I've tried the fx straight after a battery change.
    Its actually one of the nicest electros I've heard to be fair! It's a Faith Saturn fwiw, got it years ago for a ridiculously good price and it completely blew away the Martins, Taks and Simon Patrick I tried at the time. So there!
  • ^ smiley no worky.
    I don't doubt that it's a nice guitar, but I absolutely detest every Shadow piezo system I've ever heard. Horrible, horrible piezo "tone".
  • Fair one dude :)
    More seriously, how are you setting the EQ? That's really what I meant - if you've got the bass up high and the mids and the treble low, a wah will probably seem to not do much, since its frequency sweep is in the mid-treble range. I'm not familiar with the TC so I can't comment on that.
    Try changing the battery first though :).
