Blackstar HT pedal power supply question
fretmeisterfretmeister Frets: 24697
Most of my pedal board is powered by a Voodoo Labs Pedal Power 2. I understand that the regular outputs cannot power the HT range of pedals.
But the Pedal Power 2 has a courtesy output that is basically a mains output - but limited to 200 Watts (so not for powering an amp!)
Can the HT power supply be safely plugged into the Courtesy Output? (Yes I know I'll need an adapter or cut the regular 3 pin off and replace it with the right end of an IEC connector!)
Perhaps @ecc83 can help?
ta
  • ecc83ecc83 Frets: 1640
    ta
    Yes Mr F that is perfectly in order. You could run about 10 HT pedals from a 200W mains outlet!
    Are you running an old AC powered pedal (16V 800mA) or a new 22V DC jobbie?
    Dave
  • fretmeisterfretmeister Frets: 24697
    About to order a new HT-Metal
    So 22V I suppose.
    Thank you!
    you like you high gain pedals i notice!! ;)
    I keep changing my mind on what to buy though!
