Amp build ideas needed for massive transformer ...
4114Effects4114Effects Frets: 3131
edited October 2017 in Making & Modding tFB Trader
Have a random transformer here - it's a beast of a thing, so I need suitably mad amp circuit suggestions to use it in.
Specs are:
5v at 3A
6.3v at 7A
75v at 100ma bias
450v at 250ma
Ideas so far are some kind of valve bass amp - 2 or 4 KT88 should be no problem for the TX
Any more suggestions?
  • RavenousRavenous Frets: 1484
    The 5V output makes me think of digital applications. So a valve amp with some madcap digital processors built into the front end..?
  • 4114Effects4114Effects Frets: 3131
    5v is for a valve rectifier :)
  • ICBMICBM Frets: 72418
    250mA isn't a lot at 450V - that's barely enough for a typical 50W amp.
    Heh I have never poked around in a valve amp, so I wondered why on earth it would need 5V and 6.3V!
    Thanks.
    What a strange transformer it is then ... hmmm
    It's the 7A 6.3V rating that's surprising - even a pair of EL34s don't draw anything like that, and that's probably the highest power valve draw it would need to handle give the HT rating - but what if it's designed for something with a huge number of preamp valves...
    All-valve digital modelling amp? ;)
    About the size of a Google server building, and preferably built in Greenland to save on the cooling bills....
  • normula1normula1 Frets: 640
    Perhaps it's from a hi-fi amp which would have double the number of valves.
    And in the old days, a - highly dangerous by modern standards! - multi-pin connector to supply a separate preamp with power, since they usually didn't have a PT of their own.
    That would make sense. So you could be driving four EL34s in the power amp - although at fairly low audio output power, so no need for a big HT current - and possibly 6-10 preamp valves depending on how complex the preamp was.
  • NomadNomad Frets: 549
    Four channel guitar amp, each channel having lots of gain options, and independent EQ, reverb and tremolo. Maybe some valves for silent switching?
    Nomad
  • MartinBMartinB Frets: 209
    From an old valve-based organ, perhaps?  Those had large numbers of preamp valves and usually only a small power amp, and are the kind of thing that might get broken up for parts nowadays.
  • Modulus_AmpsModulus_Amps Frets: 2583
    is it a matchless spec PT, that heater current may have been used to power those little bulbs in the amp.... and some Christmas lights too
    I could use it to power an amp and a load of LED stage lights ... :)
    Which Matchless would use a B+ that high? Not the EL84 ones I'm guessing ...
    No EL84's for sure, I would try something with big bottles, Like KT88's
    Yeah, 2x KT88 into a 4.5k load seems about right for the TX. Maybe a Hifi amp ... hmmm
    The Phoenix is 2-EL34, although I don't know what the HT voltage is.
    Good call. It must be something of this general spec, anyway.
    Deffo not from an organ. It's a modern production TX from Danbury.
    I inherited one of those. The mains lead came into the preamp chassis which had the power switch and from there was a two pin AC power cable to the power amp chassis and a separate eight pin Bulgin? plug for the pre-amp signal going one way and DC power and heater going the other way. This connector also provided ground.
    I still have the power chassis albeit now fitted with a proper IEC mains socket and the eight way connector well and truly disconnected :)
    It wasn't uncommon to have the mains cable going to the power amp, but the on/off switch on the preamp - next to the controls obviously - so the multi-pin connector carried ground, signal (x2 if stereo), filaments, HT (usually around 250VDC) and two live mains wires, one unswitched... all down a lashed-up cable bundle with some shielded and some unshielded wires all in a loose rubber sleeve!
  • martinwmartinw Frets: 2149
    I know what it is! ;)
