Fractal FX8 expression pedal (wah/volume)
imalrightjackimalrightjack Frets: 3752
I've been looking at the Mission SP-1 but it's unclear whether I can use it for volume and wah with the toe switch?
Ideally I'd like it to be volume by default and switch into wah.
If not the SP-1, any recommendations?
Thanks!
Trading feedback info here
My band, Red For Dissent
  • RolandRoland Frets: 8714
    Mission's web site says "... the SP-1 has two output jacks, one for the expression pedal and one for the switch". I'm not familiar with the FX8, but if it's anything like other Fractal gear then the same switch can be used to switch Volume off and Wah on, and vice versa.
  • simonksimonk Frets: 1467
    I don't have an SP-1 so can't test it, but I'm unsure it'll work the way you want. Either way you'd have to assign two blocks to wah and volume which would only leave 6 left.
    I use an EV-1 with the FX8 and have two identical patches, one for volume, one for wah.
  • Hi, @simonk , I'm yet to get into it yet but presume that means I've six stomp slots available in a basic 'scene'?
