Also a K&K-friendly 1 meg input.
Oh and maybe a notch filter.
Phantom power is only capable of a small current, you wouldn't be able to power a pedal with all those features from it. External 12V AC would be my choice as it's then quite easy to make a dual 12-0-12 supply internally which gives excellent headroom and does away with a lot of coupling capacitors
I would like a mute switch as well on the pedal and the high pass set about 12dB per octave but adjustable from 80hz to 150hz
Does a high-Z input like that have any downside for other pickup types?
I'd assumed Tuner switch would double as mute (or even just have that switch route to a single send that a Tuner could be plugged into maybe ? )
OK so minus comp and reverb how cheap is cheap ?
You really need a completely separate hi Z piezo pre amp as well as a low Z line pre amp to get the best performance
In terms of cheapness it would cost about £45 in parts for the box and sockets, pots, opamps and supporting circuitry for preamps, EQ, hi pass filter etc ....
I'm in the process of finalising an usual pedal design myself at the mo, I've designed and built the prototype and am currently giging in and making notes and adjustments before the circuit diagram is confirmed good and it then gets put into SPICE which makes a PCB layout which goes off to a PCB fabrication place.
Then I have to buy and drill the box's to build the units, so I will learn more about the process as I go I guess
I’m surprised there aren’t more like this on the market.
Sounds like an interesting process - be cool to hear about it as you go!
Why do they even make it like that?
The AD-8 is too big, the AD-2 is too basic, the old AD-5 wasn't footswitchable, and the AD-3 has the damn chorus and no tuner.
FAIL.
https://www.andertons.co.uk/p/PZPRE/acoustic-guitar-fx/radial-engineering-tonebone-pz-pre-acoustic-preamp-di-pedal
http://www.gracedesign.com/products/alix/alix.htm
Fully parametric mid EQ with switchable range, switchable input impedence, and a courtesy 9v *out*
