Upgrading my Telecaster - How Far Should I Go?
  • Axecaster seem to be one of the good guys, and it would be bad business for him to recommend a duff item, so I'm confident you'll like it :)
    It's addictive, I'll warn you. I have a Tele body that needs electrics. And a neck.
    Probably won't be done till the end of the year, which is a bit sad, but I know it'll be a stunner!
  • asimmdasimmd Frets: 115
    Well that was the reason I chose a cheapo,then if I made a pigs ear of it,it wouldn't hurt quite as much. If all goes well I already have a project Strat in pieces,body was black but now it's down to bare wood. I'm always worried about getting a neck and body in case they don't fit properly,I don't have the facility to do any woodwork. If it works out I will find out how to post pictures on the forum and you can all tell me if I did it right. Alan
  • It'll be fine, and there are loads of folks who helped me with all of my quibbles. So you're in safe (relatively) safe hands ;) just enjoy it. You've got a guitar you quite like but want to iron out the flaws.
  • GSPBASSESGSPBASSES Frets: 2351
    I use the Gotoh contemporary Tele bridge cost about £50 it will fit new and vintage bodies its really good well made the intonation will be right for all 6 strings.
  • GruGru Frets: 339
    http://www.wdmusic.co.uk/gotoh-contemporary-tele-bridge-2173-p.asp
    I have been looking at that bridge myself while contemplating modding my classic vibe sunburst. While I appreciate compensated saddles, I prefer to have individual adjustability.
    Although before I do anything I really need to consider whether I want the blacktop Strat I have seen.
    Looking forward to seeing how your molded tele turns out
    I ordered a genuine Fender 6 saddle replacement bridge from Axecaster.
    Just fitted it and it is perfect,all i have to do now is string it up and set the intonation.
    Bridge costs £20.95,excellent.
    Alan
    I've got one in Chrome, found it for about £30 and it is an absolutely quality bit of kit.  I chose steel saddles, but you can get brass ones if you are so inclined.
  • mrn1989mrn1989 Frets: 240
    Out of interest where did you get the tele from, in after a cheap tele to mod
    Fretboard Feedback https://www.thefretboard.co.uk/discussion/58705/  ALSO Over 500+ 100% feedback eBay transactions
    Go to Facebook and look up Alan George Guitars.
  • Just given me a bad case of GAS .
    Alan George Guitars has some cracking stuff .gonna try and get a bigsby like tremelo off him! ;-)
  • furtherfurther Frets: 88
    Hi
    What's the finish like,would it be easy to remove ?
    The finish looks like varnish over wood with a gloss lacquer on that.
    I wouldn't try to remove it,but i am happy with the colour.
    My luthier is going to sort it in about a month when he catches up
    with his backlog of work.
    Thanks
