Modeller clean sounds a bit “piezo”?
So I’ve been experimenting with various amp modellers and noticed that many of them have a strange piezo quality to the clean sounds.
It’s hard to describe but it feels like a bassy thump when you hit the strings and a lack of the instant response that I’d get from a real amp.
I’ve tried to EQ cut the bass, which helps but still not quite there - anyone got any tips for getting great modelled cleans or am I just being too fussy?
Link to my trading feedback: http://thefretboard.co.uk/discussion/58787/
  • John_AJohn_A Frets: 3775
    What modeller, what amp (virtual), what guitar?  'piezo quality ' suggests you need a high-cut, probably 4-khz or at least a cut around that band with a parametric EQ.
  • @John_A  it’s something I’ve noticed with various guitars and clean models (helix, AmpliTube, UAD).
    some are better than others but I wondered if it’s something that others had noticed and if I was missing a common trick to get better clean models.
    interesting point on the high end, will give that a try also.
    Odd, I find clean sounds the easiest.  I like a bit of grit on them, that seems to smooth it out and make it less hi-fi
  • Ah, maybe that’s the key I’m missing! I might be making the cleans too clean where they’d benefit from a bit of grit.
  • ICBMICBM Frets: 72408
    I hear that characteristic in a lot of modelled sounds, both clean and dirty. It's what I've always assumed people mean by 'sounding digital', since that's how I would describe it.
    Are you going through FRFR speakers/headphones?
  • Hi @ICBM  I am monitoring through both studio monitors and headphones.
    It it is that “sounding digital” thing I’m hearing.
    The funny thing is that I don’t perceive anything like as much when I use a real amp + impulse responses.
