And welcome to theFretBoard.
1) Does the donor guitar have a fixed bridge or some form of vibrato?
2) Do you propose to shave the neck down or spread the four strings across the width intended for six strings?
3) Do you propose to run the four strings at the existing saddle spacing for the ADGB strings or set them wider apart?
If your donor guitar has a fixed bridge, you should be able to fill and redrill to achieve any string spacing you desire using these.
