Toronado trem suggestions
ewalewal Frets: 2587
edited November 2017 in Making & Modding
Any suggestions of trems I could add to my Toronado? I don't want to spend Bigsby prices if possible. Thanks
https://i.imgur.com/Y9cc0AC.jpg
The Scrambler-EE Walk soundcloud experience
  • ICBMICBM Frets: 72415
    A licensed Bigsby or a copy is probably the least expensive option, in fact.
    Unfortunately that's a very difficult guitar to add a trem to, and especially cheaply. As well as some sort of trem tailpiece, you will need to change the bridge since the saddles aren't grooved and the strings will slip off. (You may be able to get away with some cast-block saddles, some of those are grooved.) You then need to make sure there's enough clearance for the strings to pass over the top of the back edge of the bridge, and to keep enough break angle over the saddles you will need to shim the neck fairly heavily.
    I went through a lot of discussion about this for a customer a while ago…
    He sold it and bought a humbucker Jaguar in the end - it was easier and cheaper.
  • MartinBMartinB Frets: 209
    I had an Axl guitar with a similar hardtail strat bridge, where I added a b5 style Bigsby copy.  I used a Wilkinson 3-saddle short tele bridge with notches cut at the back for the strings to pass over.  That worked well, as long as the saddles were lubricated at each string change.
  • ewalewal Frets: 2587
    Thanks both. I think that's enough to persuade me to keep the guitar the way it is:-)
