one guitar to rule them all
  • The thing with the yammy is, they're so bargaintastic, you could get one used cheap enough to replace the neck down the line to a shape you're more comfortable with - there should be plenty of luthiers who could do it :)
    Fretwired;166612" said:
    Amazing!
  • @nickp
    Certainly a wide variety of tones available from them
    www.maltingsaudio.co.uk
  • JayGeeJayGee Frets: 1260
    edited February 2014
    ICBM said:
    A PRS SE with a Duncan P-Rails in the neck and a higher-output humbucker in the bridge, plus a split to give either the inner or outer coils - you can do this with two push-pull pots, or a 3-way mini-switch - will give you pretty much what you want without routing for a third pickup.
    Didn't the (full fat, USA) PRS Johnny Hiland signature model come pretty close to this sort of functionality?
    As I recall it had a trick (asymmetric coil split?) bridge pickup which could get Pretty Damned Close to a Fender single coil sound, a more conventional neck pickup and some clever wiring which let it go all the way from Nashville twang to Clapton woman-tone via cool jazz with just two knobs, a three-way switch, and a push-pull on the tone control. Not sure what sort of price they go for (not many around for some reason - don't know why because it was a stonking guitar) but it's probably one of the PRS models which has most appeal to me...
  • SG2000 has the best access to high frets that I've ever come across, and it is a very versatile guitar sounds-wise. Consider it.
    Or if the 2000 is a bit pricey, try the 1000. Same shape, you might give away a bit of sustain for the bolt-on neck (as opposed to the 2000's thru-neck). not sure if s/h price is within your budget though but worth checking out
    Assuming all SG1000s are the same, mine has a glued in neck like an LP but with great upper fret access.  Sorry, not for sale though.
  • ICBMICBM Frets: 72448
    There's an SG800 - a rare model just a little more basic than the 1000 - for sale in the shop I work for at the moment. It's very nice...
  • munkymunky Frets: 9
    I have a Pacifica 510v for sale at the moment - I'm sure you could get a neck pickup fitted? Otherwise it ticks your boxes...
  • @Islandape sorry! I should have said set neck.
  • monquixotemonquixote Frets: 17642
    Pacifica 812 is indeed a beast of a guitar for naff all money.
    I have a PRS Singlecut and the top fret access is really good.
  • TTonyTTony Frets: 27622
    ICBM said:
     Duncan P-Rails
    A pair of those would give you most (?) sounds that you'd need, and could be easily retro-fitted into any twinHB guitar, which might make it easier to find a guitar that works for you, and then just swap the p'ups.
  • HAL9000HAL9000 Frets: 9688
    As far as I can see,  pair of P-rails gives you something like 15 pickup combinations...
    HB HB
    HB P90
    HB S
    HB Off
    P90 HB
    P90 P90
    P90 S
    P90 Off
    S HB
    S P90
    S S
    S Off
    Off HB
    Off P90
    Off S
    That would be very versatile indeed. I'm not sure but guess the wiring/switching arrangements could be on the difficult side?
    No, not really - or rather, it could be complicated to wire up but would be simple to use. The easiest way is to use the Duncan switching rings for the pickups, but a lot of people find them ugly or a bit fiddly in use.
    An easier way is to decide which out of the two humbucking options you want - series or parallel - and then you can use two push-pull (or push-push) switches as a coil split switch and an inner/outer coil switch, which gives nine options. Or if you don't mind drilling the guitar you could fit two three-way minswitches which would give you those options independently, which is maybe easier to use on the fly.
    You definitely don't have to use two P-Rails either, one in the neck combined with a normal higher-power splittable humbucker in the bridge would actually give you more different sounds.
  • nickpnickp Frets: 183
    as usual guys you have outdone yourselves :)
    general direction sorted - to those offering sales of various geetars - that'll have to wait until a few more gigs have been done and a few more forty quids have been stuck in the back pocket to fund the base guitar.
    that was interesting :):)
  • axisusaxisus Frets: 28339
    HB HB
    HB P90
    HB S
    HB Off
    P90 HB
    P90 P90
    P90 S
    P90 Off
    S HB
    S P90
    S S
    S Off
    Off HB
    Off P90
    Off S
    I did the 'everything' switching with mine, but didn't like it. Too fiddly to change, not everything was 'that' distinctive to my ears, couldn't remember where I was sometimes and couldn't see the mini-switches on the pups without glasses on to remind me.
    Swapped to 3 positions only - P90 neck, 2scs in the middle and humbucker bridge. I LOVE it like this!! best guitar ever!
    I always assumed that the S-D triple shot pickup ring switching gadgets weren't really intended for "on the fly" gigging use and that in practice you'd just set them to give a set of sounds you could work with and then leave them there until/unless you had a gig/session which would be better served by a different configuration - kind of like a poor man's version of the Enie Ball "Game Changer"[1] programmable switching system.... On that basis it makes perfect sense but I can remember getting horribly confused at times by my old Kawai Aquarius[2] which had three splittable humbuckers with a three three way switch (HB/OFF/SC) for each pickup...
    [1] Whatever happened to that anyway...
    [2] Brilliant guitar!
  • chillidoggychillidoggy Frets: 17136
    Another vote for the Yam SG here. Mine has coil tapped pickups, too. Sustains so well, and the best quality guitar I've ever had.
    Ernie Ball's lowest moment...
