CTS push-pull pots
josojoso Frets: 1
edited November 2017 in Making & Modding
After ruining 1 pot I found out the front board can be removed for soldering contacts. After it is replaced.
Any comments ?
http://u.cubeupload.com/mrbluesfinger/IMG1232.jpg
  • TTonyTTony Frets: 27628
    Thread moved to M&M where it's more likely to get a reply ...
    How did you ruin the pot?
  • FunkfingersFunkfingers Frets: 14495
    The chances of a reply would be even greater if the opening post included a definite question.  B)
  • ICBMICBM Frets: 72482
    Any comments ?
    I'm guessing that the switch itself doesn't come apart, it just unclips from the part of the pot which operates it? Since from your pic it looks like the whole switch is still attached to the back of the PCB.
  • Modulus_AmpsModulus_Amps Frets: 2583
    Any comments ?
    yes, don't ruin your pots again... hopefully you have learned how to avoid it
  • josojoso Frets: 1
    Well,  one small eyelet during soldering dropped out and connection was lost. Anyway, StewMac tech does not recommend taking off the  board with eyelets. Soldering to be done  as it is . Grounding of lug 1 to be done on the side of metal pot with a jumper wire.
    I expected that CTS would make a better product . Little disapointed with it.
