Will it fit or will it not? :-)
Have you seen this?
The clear height beneath a PT Nano/Nano+ is 32mm including the 10mm high rubber feet. I believe the Fuel Tank Jnr is 35.5mm deep so will not fit. The Cioks DC-5 and Adam are 31mm deep so will fit.
The rubber feet of the Nano/Nano+ are riveted on. The rivets have a 10mm dia flange so are probably 4.8mm dia. They'll need drilling out to fit taller rubber feet - probably 15mm high. Alternatively additional taller feet could be fixed alongside the existing ones using self-tapping screws. Either way there's a bit of work to do to use a Fuel Tank Jnr.
http://www.diy.com/ then paste this product code 3663602991861 (for some reason the direct link doesn't like being copy and pasted!)
BTW - just how far does the fuel tank jr protrude out beyond the regular feet? And, is there enough width in the Pedaltrain for the fuel tank's 9v cables?
The 9v cables fit in perfectly with a few mm to spare:
PS: there was velcro between the power supply and board, not just the sole cable tie!
