Acoustic set up?
Is it the same things as setting up an electric?
  • Winny_PoohWinny_Pooh Frets: 7771
    edited December 2017
    More hassle dealing with the saddle.
    Get the neck as near to straight as you can, then you can have a look at action and intonation. If you have a small set of files you can look into cutting a custom saddle with ideal intonation. Here's a bone saddle I cut from a blank:
    https://i.imgur.com/Z738QJM.jpg
    You start after setting the height and intonate using a length of old plain string for the string to rest on, mark the ideal spot and later shape away, sand and polish.
    Older acoustics may have a hump in the upper frets, if its too extreme then levelling alone wont fix it.
  • ICBMICBM Frets: 72412
    Essentially, yes - although generally you want a higher action than you would on an electric. Even those acoustics which 'play like electrics' (eg Taylor) are still slightly higher.
    As Winny_Pooh said, getting the bridge right is a lot more hassle, and you have far less opportunity to try going too low and then back up again if it's wrong which you can do easily on an electric, so it's best to take your time even if it means having the saddle out more than once.
    I also compensate the top edge of the saddle usually, but I don't measure it - I simply cut two straight ridges, one running from front to back under the E and B strings, and the other from front to back under the other four. It's very rare that this isn't dead on.
  • @ICBM... when you say 'you want a higher action than you would on an electric'... is this at the nut... at the saddle... or at both the nut and the saddle?
    Thanks
  • KilgoreKilgore Frets: 8600
    Thanks
    For acoustic, playing style is a big factor regarding set up. Bluegrass players for example often prefer a high action. If you have a light touch, maybe play a lot of fingerstyle then you can get away with a lower action. For me comfort is the primary factor.
    Regarding the nut, if an F barre is uncomfortable, I would want to lower it. There are lots of Youtube videos that will walk you through an acoustic set up.
    @ICBM... when you say 'you want a higher action than you would on an electric'... is this at the nut... at the saddle... or at both the nut and the saddle?>
    At the bridge, and a bit more relief in the neck usually. The nut should be pretty much the same height.
  • @ICBM... thanks.
