Just wondering how you all set your lights up.. We did a gig on Saturday with our usual setup and video'd it but looking at the footage I don't think we're using the most of our lighting.
We have 2x4 Colour NJD lights with a controller, same as these:
A Jellyfish:
and 4x Par 56 Cans:
We also have a 4m Trussing on stands.
How we usually set up is to have the NJDs at the corner of the trussing with the jellyfish in the middle, usually pointing up at the roof (not sure why we don't point it down now that I think of it). We then have 1 Par Can for each band members usually at the front of the stage. The PARs are obviously static colours where the NJD we usually have on a chase pattern (the controller has a sound activated one as well but it's too sensitive for live use and just makes them go crazy), the jellyfish is on a random pattern).
None of ours are LEDs so you could cook your bacon buttie on the stage by the 2nd set.
So, how do others setup their lights, and what do you use?
I'd put the PAR cans on the floor at the back to give a couple of washes (one pair blue and one pair Red)? Either onto the back wall or to silhouette the band. Or maybe two on the truss and two on the floor.
The NJD multi lamps Would be on Tripods slightly out front but facing back to light the bands faces.
Used in combinations or singularly these features would give you half a dozen moods which could then be enhanced by the speed of the NJDs. Also build the light 'show' during the set and never give it everything until the end.
Don't underrate the simple idea of a single white flood under the drum throne as a cheap effect.
A cheap 4 ch dimmer and DMX controller would make more of the PAR cans (look used as people are dumping big lights for LEDs so prices are cheap).
