Marshall JMP-1 with a TC Electronic G-force
how can i coonect my Marshall JMP-1 with a TC Electronic G-force. I looked in the manuals but they are so confusing!!
  • JetfireJetfire Frets: 1696
    Wrong forum mate, this is for selling stuff!
  • stratman3142stratman3142 Frets: 2198
    edited December 2017
    You might find some useful info on the thread at the link below. The discussion in the link related to a JMP1 and a G Major processor, but I expect things will be similar for a G-Force processor.
    http://www.thefretboard.co.uk/discussion/comment/1679852/#Comment_1679852
    Basically you could connect it in series or parallel. Some preferred serial (i.e. JMP1 > Processor> Amp).
    I preferred to connect my processor in parallel, which then required it to be run 100% wet (doing the mix in the JMP1).
    It's not a competition.
  • RolandRoland Frets: 8723
    Moved to FX
  • can you write down exactly what order (what cables go where) i should connect my jmp1 to my g -force thanks
  • ok
  • There are two options. I can’t pick one for you
    either:
    jmp-1-> g-force left input
    gforce left output -> jmp-1 FX return left
    jmp-1 left main output -> power amp
    or
    jmp-1 main out left -> gforce input left
    gforce output left -> power amp
  • ok thanks' i'll try it tomorrow
  • hi, i've got no sound coming out/from the gforce
