I have a nice PRS SE Soapbar. Nice as in it plays in tune, stays in tune and feels fine to play. Well playing (it) acoustically it does. The problem is that the soapbars sound spiky and shrill when plugged in. I solve this problem by rolling the tone way down which kinda kills the sound to a large extent. My opinions of the supplied P90s are close to being unprintable.
My question is - it is worth upgrading the pickups or is the default P90 sound spiky and shrill? If it is worth the effort, what P90s would you suggest?
Thanks.
Nil Satis Nisi Optimum
I would also change the pots etc while you're at it.
Man that P90 has done some miles !
Good call on the pots too @Adam_MD - I prefer CTS pots, but some people swear by Alphas. Just good ones helps though. One thing to watch, iirc, is that the One needed the holes reaming slightly to fit full size pots in as it came with mini ones. A Switchcraft switch and jack socket are always worth doing too. Don't change the tone, but will give miles of trouble free motoring...
The stock pickups in mine (S/S/H) were overly shrill and bright. I originally put a Bulldog single coil in the neck, which transformed the guitar (in the neck position only, of course!) immensely, made it instantly sound like a guitar from much further up the food chain. Then I decided I wanted a 2 x HB configuration, and again the guitar took to it brilliantly, unlocking a whole load of tone that wasn't there with the stock p/ups.
So, others can advise re P90's and what to expect, but certainly an SE is "worth" upgrading the pickups on, in terms of the basic building blocks of the guitar itself.
Feedback : https://www.thefretboard.co.uk/discussion/58125/
