Squier strat rebuild
  • JayGeeJayGee Frets: 1260
    Not my guitar, ands not my business, but did anybody else look at that first batch of pictures and immediately start thinking about Dave Gilmour’s eponymous Black Strat...
  • WezVWezV Frets: 16726
    frets are out
    hmm... hadn't noticed before - that doesn't look like indian
    time to do something about that nut shelf
    my old squier provides a suitable filler piece
  • DannyPDannyP Frets: 1681
    WezV said:
    frets are out
    I just can't keep up with the trends.
    Just done the big structural plug on the front.  It replaces the existing beech and goes a bit wider and a fair bit longer to just behind the floyd route.
    it is a nice tight fit.  I put it in to test and struggled to get it out again.  It’s now been glued in place  and will be trimmed back later this week... then pics
  • gusman2xgusman2x Frets: 921
    He'll get some money back for the edge!
    i skipped a few steps in documenting this
    firstly i did the big structural fill on the front.   That would have left a hard line behind the bridge so i then inlaid a 3mm basswood veneer  to make it look like natural joins in the body, and a feathered join on the contour. which will blend better than a hard join at right angles to the grain.   The other way i was considering was to route out a  big deep strip down teh middle and put one big fill in, but the way i did it keeps more of the original wood.
    It now looks like this
  • GizmoGizmo Frets: 1076
    Nice
  • normula1normula1 Frets: 640
    That's f**ing brilliant. Way better than I hoped for. :star:
    That's a fantastic bit of plugging!
    Floyd....   What Floyd???
    again i have progressed quite far and forgot to take pictures
    You may remember the back looked like this
    the spring cavity had been extended , the block section had been widened etc...
    i did pretty much the same as the front.   I first filled the block section.   Then i filled most of the spring cavity.  once they were set in place i routed a wide shallow slot for a veneer  to cover it all up.
    The heel had been angled, which is a mod i thoroughly approve of so the contour has been preserved.   it does mean we have another feathered join line on the veneer, but those are less likely to show up than a hard joint
    You can see a slight trench near the end of the srping cavity... i didn;t join the plugs fully here as its a non structural join.  when gluing up the plugs i used some wedges in this gap to push both plugs  tight against the important glue surfaces
    Wow. Mrs Normula1 just said "is that really your guitar?" :)
    ha.  Definitely still your guitar.
    i am going to leave the body alone for a few weeks now so it can settle in.  concentrate on the neck.  Then once its fretted I will put it together for a test fit and see if I need to make any changes before finishing
    Lacquer has been on for a week or so now.   Needs a few more weeks before levelling and buffing out
    Ooooooooh :)
    going back together.  It still needs the nut cutting but i am really happy with the transformation so far
