Converting a Lemon Drop into a Lucy - PICS!
  • DannyPDannyP Frets: 1681
    stickyfiddle;174243" said:
    FAAAAKKKEEE!!! :p
    Looking good though :)
    Ha, yeah! If Orville is watching, this is just a stage prop, ok!
    @WezV - yes a veneer is a good idea. That also leads into my next challenge - bridging the bottom of the truss rod cavity so I can use a 2-screw TRC.
    A reasonably substantial veneer could aid this maybe?
  • impmannimpmann Frets: 12668
    Just use a long screw with a spacer washer?
  • I suggest you don't bridge it, just attach the a piece of the same veneer that fits snugly into the truss rod cavity to the back of the cover and add a dummy screw to the bottom end.
    The TRC is fixed by a single screw at the top but can't slip as it's held in place at the other end.
    FAAAAKKKEEE!!! :p
    Orville is only a stage prop himself!
    Ooooh, you mean...the other Orville....?
  • WezVWezV Frets: 16726
    it could, but try not to make the overall thickness too much. i would go standard veneer thickness (0.5mm) on the back (mahogany type)   and structural veneer(1.5mm) on the front (holly, maple, sycamore).   if that extra 2mm is too much for your tuners then you will need to thin the headstock face first but in most cases it should be fine
    glue in a small block of wood as the bridge over the truss rod cavity before veneering
    edited March 2014
    I've done some sanding and filing (or 'rasping', if you're a pendant ;) ) on the headstock to help the new chunk merge with the rest.
    I've also reamed the tuner holes out to 10mm to take the Rotomatics.
    http://i611.photobucket.com/albums/tt192/p1eces/Mobile%20Uploads/20140301_174853.jpg
    @WezV - if I were to go down the veneers route, do you recommend a supplier? I've had a quick look on eBay and Amazon, and there are some out there, but any secret suggestions? Do I get stuff with adhesive already applied/iron on?
    Many thanks
    you don't need much at all.  i would offer to send a couple of headstock sized pieces but my workshop is currently packed up in storage so i don't have access to it
    I have only ever used normal plain wood veneers so can't comment on iron on ones
    try ebay for small amounts, like these samples
  • GuitarMonkeyGuitarMonkey Frets: 1883
    edited March 2014
    I've got some 0.6mm veneers in maple and mahogany (well, sapele). PM me your address and I'll send one of each.
    Nice job!
    Thanks for that offer GuitarMonkey, I have PM'd you.
    http://i611.photobucket.com/albums/tt192/p1eces/Mobile Uploads/20140304_141439.jpg
    Little bridge bit glued in now, so I can use a 2 screw TRC.
    Plus I can still adjust the truss rod which is a bonus!
    @GuitarMonkey is VERY kindly sending me some veneer which will cover the whole thing.
    edited March 2014
    Posted at lunchtime today RM 1st class post and should be with you tomorrow.
    You are an absolute gentleman. Pressure's on not to f*¢# it up now!
  • Adam_MDAdam_MD Frets: 3420
    You'll be grand you've done fantastically well up to now. I'm looking forward to seeing it finished.
  • LixartoLixarto Frets: 1618
    Seeing it finished?
    I'm looking forward to hearing "Something".
    Nifty!
    edited March 2014
    Sorry for the hiatus, my laptop has stopped working, but I'm here via android.
    So... welcome to headstock week!
    The veneer kindly donated by GuitarMonkey arrived safe and sound.
    http://i611.photobucket.com/albums/tt192/p1eces/Mobile Uploads/20140305_133104.jpg
    I also received these:
    http://i611.photobucket.com/albums/tt192/p1eces/Mobile Uploads/20140305_123851.jpg
    edited March 2014
    Veneers on :
    http://i611.photobucket.com/albums/tt192/p1eces/Mobile Uploads/20140310_175346.jpg
    I hadn't noticed before now but the headstock is on the piss a bit. Look at the curves either side of the truss rod cavity running from the sides of the nut up to the corners below the 2 e-string tuners. Totally lopsided! Ah well.
    Here's the back with a bit of stain on it:
    http://i611.photobucket.com/albums/tt192/p1eces/Mobile Uploads/20140311_075728.jpg
    Ps, when I paste 'direct' links from photobucket, I see the image itself in the post on my laptop, but only the link text when viewing the forum on android, what's that about?
    well those pics are all a bit muddled up with your descriptions, but it looks like you are on the right track
