Flanger/chorus/phaser in one pedal?
Chris_JChris_J Frets: 140
Can anyone think of a decent pedal that'll do flanger, chorus, phaser, but, has power consumption under 100ma?
  • lovebuzzlovebuzz Frets: 104
    nope
    Under the bridge downtown
  • John_PJohn_P Frets: 2750
    mooer mod factory?   Slightly more current at 128mA though.
    http://www.mooeraudio.com/?product/201409271369.html
  • Chris_JChris_J Frets: 140
    This is best I've found so far...
    https://digitech.com/en/products/nautila
    Not familiar with digitech pedals... any good?
    If you don't need the phasor then if can find one the fulltone choral flange is only 35mA and pretty decent.
    https://www.fulltone.com/products/choralflange
  • Nebulus
    edited December 2017
    doesn't do phaser, does it?
    digital modulation effects are inferior to analogue ones imo,
    i cant think of an analogue chorus/flanger/phaser pedal.    phaser doesn't rely on delay for its effect.
    p.s.
    The Marshall Regenerator does all I think.  digital, but only 80ma.  very affordable to get nowadays.
    Thanks guys. I should have said I'd prefer analogue, but, was struggling to find what I was looking for.
    Will do some more digging!
  • sgosdensgosden Frets: 1994
    marshall regenerator is cracking for the price, but by no means 'perfect' sounding.
    you not able to run another power unit ?
  • timbuk02timbuk02 Frets: 271
    ZCat Q-Mod has these and reverb as well...
    Specs:
    • Input Impedance: 1 M ohms
    • Output Impedance: 1 k ohms
    • Recommended Load Impedance: 10 kohms or greater
    • ADC-DAC HF response (-3dB): 20Hz-14.5 KHz
    • THD (1KHz, -1db from clipping): 0.015-0.03%
    • Current Draw: 80-90 mA (DC 9V)
    • Dimensions (mm): 72 (W) x 111 (D) x 50 (H)
    • Weight: 210 g
    ah sorry, just saw you said analogue preference, which I can't see if this beauty is either. Nice tho!
    Current draw is ~50 mA.
    southampton pedals - utility knife Multi-Mod
    Great suggestions, thanks!
    The digitech pedal you mentioned is digital, i believe.
    If you only want analogue, you're likely to have to get two separate pedals as a minimum.   as i said before, I cant think of an analogue pedal that does all three effects,.
    The current EHX 'stereo electric mistress' model does chorus and flange and is analogue; i dunno how good it is though.   You could pair it with a EHX neo small stone phaser.   that would together be a reasonably affordably solution.
    p.s.
    If pedal board space is important in your decision you could get the following three Mooer micro pedals (all are analogue):
    - chorus ensemble (ce2 clone)
    - elec lady / e-;lady (e/mistress clone)
    - orange 90 (phase 90 clone)
    Yes it is digital, so not quite what I'm looking for.
    Basically, my board is pretty small (which I like) and I have space for 1 modulation pedal, but, play in a function band occasionally covering a wide selection of genres.
    It guess all 3 aren't essential as most people won't care as long as they recognise the song etc
    Maybe just a decent flanger then as that could cover chorus duties too?
  • dindudedindude Frets: 8537
    Could you find room for two mini pedals? If so the Mooer Eleclady is an excellent flange and the Ibanez Mini Chorus is great too - both tiny, cheap and anolog.
    i'd suggest a chorus over a flanger
  • ab2017ab2017 Frets: 20
    Mooer phaser and elec lady with a pedal connector lol
    I reckon the Digitech Nautilia you mentioned is a pretty good bet, i've been watching videos of it today and it sounds ace.
    My trading feedback can be seen here - http://www.thefretboard.co.uk/discussion/58242/
  • GadgetGadget Frets: 895
    How about the Neunaber Slate (or any other in the Expanse range)? They can all be set-up with the free software to do whatever effect you want and even switchable between 4 choices live if you get the Exp pedal. 100mA power consumption. Not analogue, but fantastic sound quality.
    I think, therefore.... I... ummmm........
    lovebuzz said:
    nope
    Not even Sharptone?
    Sassafras said:
    lovebuzz said:
    nope
    Not even Sharptone?
    eh?
