Vocal mic for speech
koneguitaristkoneguitarist Frets: 4191
edited December 2017 in Studio & Recording
looking at updating or replacing one or two of our studio mics in radio station. What's best options to look at below £200 each? Currently using audio Technical AT4033a Condenser mics.
  • Winny_PoohWinny_Pooh Frets: 7838
    New or used? You wont get better condensers than the AT at that budget. Perhaps look for a used beyer m88 as re20s are priced quite high. Most of the dynamics used for guitars are not great for speech but the Beyer m201 could do.
  • Used... If you can find one a Shure sm7b is a good shout
  • robinbowesrobinbowes Frets: 3058
    You might get a couple of RE20s for that price, but probably not.
  • Didn't realise how expensive the mics are that we have.
    One definitely sounds more nasal and lacking top end than the others, wondering if these can be cleaned/renovated ?
  • ICBMICBM Frets: 72821
    If the Shure SM57 is good enough for the President Of The United States...
    Unless its super super dirty then replacing the capsule is the only option, can you take a photo of the problem mic's capsule?
    A dustbin lid with a hole in it is good enough for that bloody idiot!
    Not sure how to get at it.
    The lower end w xlr should usually have an end thats screws or turns off. Then the body sleeve slides off. Under that are screws holding the headbasket which you remove carefully making sure not to touch the capsule.
    True. But I meant the President as an office, rather than a specifically orange one :).
    The 57 has been the Presidential mic since Lyndon Johnson. Although to be fair, a lot of it is probably to do with its reliability rather than its sonic qualities.
    Ok ta.
