Envelope/ramping tremolo suggestions?
  • If you fancy tinkering with some electronics you could try RG Keens LERA bolt on for speed ramp up/down.
    http://geofex.com/article_folders/lera/lera.htm
  • lukedlblukedlb Frets: 488
    Incredible. Exactly what I require. I suppose I could take that to a pedal tech and have them install it.
    In the meantime, I believe I have found a tremolo pedal that does the brake function and more.
    More soon once the seller gets back to me.
    I’m going to try the Cusack tap tremolo.
  • TeetonetalTeetonetal Frets: 7809
    I'm trying to recall if the empress has a volume follow mode. Will have to look it up. Been ages since I used mine.
    The Cusack has arrived at my family home. Thank you @Jtaylor. ;When it arrives in Italy, I’ll update the post on how effective it is.
