Not used it on a sewage outlet, but I love the mini explosion you get when you tip caustic soda down the sink/washbasin plughole and the pour boiling water in afterwards
Nil Satis Nisi Optimum
If if not then work backwards, checking each access point.
I wouldnt use chemicals. If they don’t sort the problem, which they won’t if it’s not a grease build up, then they make matters worse. If left because the block is not cleared then they can erode clay pipes.
I do this every now and again down the bath/shower drain when it starts to slow down. Apparently it's a mix of hair and hair conditioner that clogs up most bath/shower drains. I make up a bit of solution, fill the bath with water, give it 15mins or so then drain the water. Works great and caustic soda is cheap!
As others have said, the first job is to lift any manhole covers outside the house and see what’s blocked and where. If you can bear rodding out a pipe-full of shite yourself, you’ll save a load of money on a call out charge to DynoRod. It’s not a particularly difficult job, just a nasty one.
https://twitter.com/spark240
Reddit r/newmusicreview
My wife is picking up one of those flexible coil drain cleaners tomorrow so I'm going to start with that when she's back
Can't help but think the power of the collective thoughts of Fretboarders made this so. In light of this about 30k would be really handy in my life right now - and so your collective thoughts on this would be appreciated too.
Feedback
