Fret buzz and string height
StevepageStevepage Frets: 3047
One of my guitars is giving me a lot of grief. For a while I just played with a slightly higher action just to play the guitar but now it's getting to me.
On the lower register (frets 1 - 12) are fine but once I get in the upper register (12-22) I get fret buzz and dead notes when bending.
Now I've adjusted the neck for more relief but when I lower the action at the bridge, the notes don't ring out at frets 12-22.
Can any of you help me out?
Also the neck has a shim, would it be a good idea to take that out so I could lower the neck height in the pocket?
  • richardhomerrichardhomer Frets: 24804
    You need LESS relief and raise the saddles if the problem is at the 'dusty' end. The shim shouldn't be causing the problems you describe.
  • ICBMICBM Frets: 72340
    Exactly. You need the saddles high enough that the notes don't buzz or choke above the 12th fret - that's the test of saddle height.
    It will if the saddles are already at the top of the screws though.
