Those speakers are square back Fanes though and worth salvaging. Look as though they are late 70's or 80's. Should be nice speakers IF they work properly. Get them out and test them for coil rub. Probably the best thing about the amp.
Dump it at the side of the road, seriously.
They are actually reasonably reliable usually - I had one a while ago and before selling it I proof-tested it by cranking the living daylights out of it into a dummy load for about half an hour, and to my slight surprise it was none the worse for it.
The hum on one channel is likely to be broken ground connection, which could definitely be connected (ie not, really!) to the missing Normal input jack.
Unfortunate choice of company name, with hindsight. They disappeared in the early 1980s...
electric proddy probe machine
My trading feedback thread
