FS: Nickel humbucker covers, gold tele 6 saddle vintage bridge
Parts dungeon clearout:
First up some Mojotone 53mm pole spacing nickel covers
(shiny nickel plate under the plastic finish protectors)
£5 delivered per piece - 3 left.
Same but in unpolished nickel, kind of an aged look:
Priced as above, or all 5 for £15.
A pair of packaged 50mm WD music covers
rrp £11 each, sell the pair at £12 delivered.
SOLD A pair of 49.2mm nickel covers (vintage/gibson PAF sized)
Still have their protective covers but could use a polish if you're the picky type. SOLD
£9 delivered the pair.
Allparts 'wide spaced bridge' set
£10 delivered
52mm nickel cover, never fitted but no protective cover, might need a polish:
£4 delivered
Wilkinson gold tele bridge with six stamped saddles. Drilled for both string though body or top load.
Used, fine scratches/flaws to finish etc.
£7 delivered. SOLD
Paypal gift, or add whatever fees to prices pls.
I'm away for a few days so won't be able to post until the weekend. Will message you when I'm back
I only do 49.2 vintage spaced. Sorry.
Hi @streethawk do you still have the Tele bridge? Do you have any pictures of it?
Thanks.
Some scratches and little spots of slightly thinning gold plate. The white bits on the side walls are just reflections. It's in OK condition for £7!
Looks good, I'll PM you.
