http://traynoramps.com/guitar/horses/product/dh25h/
Only 25W, but it's a true amp in a pedal.
There's also the Crate Powerblock which is only a bit larger, but it's not pedal format, sounds horrible and isn't reliable. And discontinued. (Thankfully .)
soundcloud.com/thecolourbox-1
@Van_Hayden you should definitely have a word with Jeff about it!
Also odd question but Van_Hayden are you German? If so then it was you that helped me try out a few amps and the speaker wall when I was ordering my Matamp back in 2005 ish - Also at the time there were a load of Harry Joyce amps in the showroom.
Put me down for one as well...
Thats is pretty much what I want in terms of design and knobs but I need 100 watts!
I thought the Little Smasher was only 5 watts?
Yep your right I must have got confused with something else
