Strymon Sunset Owners assemble
TravisthedogTravisthedog Frets: 1845
So I listened to the hype an bought one of these a few months back and the left hand side immediately became the best and most favourite drive pedal ever. End of
However try as I might I just cannot get anything decent out of the right pedal. On it's own or in combination with the left. It's always such a moosh of sound, without the biting clarity you get from the left.
Anyone have any set up ideas. In an ideal world I'd want to use the left as mild drive then stomp on the right to knock it into hard crunch/distortion territory
Ta
  • RandallFlaggRandallFlagg Frets: 13941
    edited February 2018
    I had the Sunset last year. I used to do exactly that. I set the left side (A) to the 'Ge' (Klon) setting and set up a light crunch and then feed than into the 'hard' (RAT) setting on the right side (B) which was set with not a lot of gain but added together it sounded good.
    The trick was to play with the volumes on each side and also try A>B, B>A or parallel until you find the tone you're looking for.
    With the amp I had a t the time I found that I couldn't set the gain on the 'Hard' setting too high or it got all flubby.
  • thomasw88thomasw88 Frets: 2325
    less is more i find with the right side.
  • It does appear that way
  • guitargeek62guitargeek62 Frets: 4137
    Not for me! I love the 2-stage and Hard modes, but I run A+B in parallel (not stacked), with the bright on neutral or +1 with the following (o’clock):
    Hard
    L: 1-2
    T: 1
    G: 2-3
    I pair that up with the Ge mode:
    L: 2
    T: 1
    G: 12
  • Yes I would agree I prefer the parallel rather than the stacking. I never did like stacking pedals anyway. However, the versatility of the Sunset is amazing should I ever wish for that sound. Love it and is the only drive pedal on my board now
