Dual AB Loopers
DopesickDopesick Frets: 1509
Just wondering the best way to go about this...
Have recently ordered an S&K VHD pre-amp distortion from the States (which is an Ampeg VH140c in pedal format - should be here in a week or two) and I'd like to use it in front of a clean amp.
Does anybody know of a good vertical aligned A/B dual looper? In Loop A I'd have a low/mid-gain distortion (like an OCD) and in Loop B I'd have the VHD distortion. There would ideally have to be two switches for toggling between A/B and another for Bypass.
Bright Onion do make one but it's horizontal and takes up a smidgen bit more space than I'd have liked.
Of course there is also the Boss LS-2 which is an incredibly viable option, but seeing as I'd only be using it in one mode (A to B) I'd like to see what else is out there first.
  • sgosdensgosden Frets: 1994
    Maybe I'm being daft, but could you just turn the horizontal one 90 degrees?
    Or send bright onion a message, they're spot on for custom jobs
  • DopesickDopesick Frets: 1509
    Lorks a lordy, a reply!
    I could turn it yes, but then that could probably make routing a bit of a pain in the arse, and also stomping on the footswitch would need me to be extremely nimble on my feet.
    Yeah I think giving them a bell is probably the best.
