String Tension question
Quick question, would 13's tuned down to D (DGCFAD) be similar in tension to 12's at Concert pitch?  Not sure of scale length, it's an S&P Dread.
  • ToneControlToneControl Frets: 11940
    I use this to experiment with gauges, I was using it just today
    http://vinic.free.fr/strings/?l=0
  • menamestommenamestom Frets: 4723
    Thanks, that's great.  It does not have every exact gauge but it's close enough.  13's a tone lower pull less tension than 12's at concert.
  • stickyfiddlestickyfiddle Frets: 27133
    I'd say yes "ish" :)
  • richardhomerrichardhomer Frets: 24834
    I do this on my D28. The short answer is there or thereabouts.
  • ICBMICBM Frets: 72485
    I tune my D35 12-string down to D with 11s on as well, instead of to E with 10s. It just sounds much better, and the tension is slightly lower, which matters on a 43-year-old 12-string with no truss rod! (Martins from before 1985 don't have them, just a non-adjustable steel rod.)
  • Yes
  • imaloneimalone Frets: 748
  • 6 string work our fingers up to heaviest gauge you can cope with for best tone
    12 string tune down half a step then as above
    www.maltingsaudio.co.uk
