If you had a tc Flashback II you could use the Mash feature to go between one delay time and another, although you’d have to keep your foot down to hold the second time.
The BBE Two Timer has two delay times and it’s own footswitch to change between them, might be bigger than you want ( non standard shape so you’d have to check).
