I acquired this lovely set from Berry on TFB couple months back. It really is a fantastic and versatile amp but I'm now looking for something different.
The amp is very clean. No bangs/battering. Only sat at home not a gigger.
Blackheart 5 valve mini stack. Fully Ratamps modded with power scaling/the works. Go to the Ratamps site if youre not familiar with Andys work. The head is boosted to 11 w. Has the matching 12” cabinet too. IIRC has an Eminence speaker.
Comes with variable boost footswitch (volume control knob on side), covers for head and cab & boxes. Plus original BH tags & the mod folder from RATAMPS explaining what's what. That also has the 11w power rating reading he took from his tweaks. These are super little set ups. With the power control/master volume you can go from 0.1w to 11w without losing tone ,they are ideal for home but still loud enough to keep up with your drummer no problem.
Head is mini sized so manageable. Has the gain/bias toggles on front. Silicon/rectifier switching, speaker 4/8/16 ohm choice.
Im asking for £290 ONO or trades with other tube amps.
Orange OR15/Cornells/MJWs/AC10/Marshall plexi style/Jubilees etc.
Thanks for looking:)
