Takes pedals really well and with some IRs and reverb you have a rig in a box that combines the best of old skool and latest tech
If it matters, if you have an amp like one of the Blackstars which does need a plug in the input to turn it on, what you really need is a 'shorting plug' - a spare jack plug with the hot connected to the sleeve. That will both make the amp work and maintain the muting of the preamp.
