Best cure for "valve rattle"
DominicDominic Frets: 16103
I know some people use elastic bands(not sure how ) but is there some little gadget / buffer to stop this or is it all Heath Robinson "home-made" ideas .......I would have thought there may be some kind of ventilated jacket or similar
If not ;what is the best "home-made" solution?
  • My HRD has a foam block with holes punched/drilled out, could probably copy that pretty easily, it looks to be PU foam.
  • ecc83ecc83 Frets: 1636
    Do the valves have spring retainers on them? These can rattle and yes you can get some high temperature foam. The Artisans have it top of the EL84s.
    Dave.
  • Modulus_AmpsModulus_Amps Frets: 2583
    you need to find out what is rattling, could the valve or the retainers.
  • ICBMICBM Frets: 72415
    A Peavey Bandit.
    9reaction image LOL 0reaction image Wow! 0reaction image Wisdom
  • p90foolp90fool Frets: 31606
    An extension cabinet.
  • crunchmancrunchman Frets: 11453
    Kemper
  • DominicDominic Frets: 16103
    crunchman said:
    Kemper
    had one............disappointing.........Helix sounds better overall
  • RiftAmpsRiftAmps Frets: 3171
    You can't ever 'cure' valve rattle, it'll always be there.
    What you can do, however, is lower the resonant frequency of the offending valve to a point below what your ears can detect, this is usually done by adding mass - either a dedicated valve damper ring (or two) or high-density foam.
    Rift Amplification
    Handwired Guitar Amplifiers
    Brackley, Northamptonshire
    www.riftamps.co.uk
  • kt66kt66 Frets: 315
    Valve coolers used in hifi can stop rattle too http://www.britishaudio.co.uk/pcoolers.html
  • BabonesBabones Frets: 1206
    edited March 2018
    I've found valve rings to be useful. Helped prevent rattle in a champ.
  • TTBZTTBZ Frets: 2901
    Thought my amp had valve rattle but it was actually V1 microphonic straight out of the box.. Might be worth checking first?
