People who have used guitarbuild tele bodies, what bridge do you use?
I have this one from Axecaster, "Fender Modern 6 Saddle Telecaster Bridge"
http://www.axecaster.co.uk/index.php?main_page=product_info&cPath=38&products_id=121Which is supposed to be vintage spaced (four screws, right spacing etc), but seemed a little too long (not so long it was impossible to get it together, but pickup is pressed against the cavity at the neck end). I'm wondering about changing it if I ever change the bridge pickup.
I quite like the individual saddles, but having to remove them to get at the bridge screws is a pain. Is the 6-barrel saddles model fender do any use and does it have the same problem about screw access? Is a hipshot one noticeably better (which would probably have to be three saddle)?
The above are all adjusted to the same scale for both height and width (the image should be at 100dpcm). So you can overlay them, lined up on the screw holes:
Two come out a little shorter than the others screws-to-pickup: the StewMac vintage bridge and the Wilkinson drawing from Axecaster (pictures of the Axecaster and Stewac bridges are different, since wilkinson is made under license they could well be slightly different). The others are pretty much the same, though I'm not sure about the Axesrus drawings, all their vintage-tele-style drawings that I could find show the same dimensions, so I think it's probably just illustrative. Looks a bit of sanding may be the only way to go, or a wilkinson if I do decide to change.
What I've got in should be a genuine fender plate too, so either it's slightly different to the three saddle (possible, but not sure why they'd do that) or it's a tolerance issue like Bron_Yr_Aur suggests.
Might drop guitarbuild an email to see if they've had other reports of this, might be they're cutting it a little shorter than it needs to be and running into a tolerance issue as a result.
@Bron_Yr_Aur, when you say touching the edge of the route, is it only just touching? On mine I had to drop it on with the pickup and then actually push the plate up into place and hold it down to put the screws in.
Decisions...
(In case of further objection to separate saddles on a classic tele, take a look at Keith Richard's 'Micawber')
Edit: option #4, Wilkinson bridge + hacksaw?
1. The pickup positioning problem - after this thread I'm approaching the 'just take a chisel to it' school of thought.
2. The annoying thing about needing to take the saddles off/completely reset the bridge if you want to get at the pickup - there's a 'do you really do this that often' question at the back of my mind here. I might change the bridge pickup once more, but after that? Three saddles may not really make any difference anyway as the barrels sit fairly close to the fixing screws.
3. Slight ringing on E and B string - going to try fitting string trees first (was trying to get away without them with staggered tuners) to see if it's the neck or the bridge. It might be this is something worth changing the bridge for anyway.
