Withdrawn - two piece swamp ash strat body - £50
Two piece swamp ash strat body originally from guitar build.
Was routed for HSH but modded so that three single coils would fit.
The neck pocket is deeper than stock - about 19mm so included is a maple shim if your neck needs it.
USA Two post trem was fitted as was the microtilt "T nut" (not included).
Treble side trem post hole has slight crack running towards the nut but it did not effect stability at all.
Copper shielded throughout cavities.
When I first got the body it was treated to a nice stained sunburst (see pic) I then changed my mind and refinished with olympic white nitro from manchester guitar tech (sunburst stain is still under there tho') Paint has sunk into the grain in places, finish also has a few scuffs and scrapes.
£50 inc delivery PPG.
Edit***** 3lb 7oz ***** See pic above
