Another Dumb Question ? Multiple USB Devices Into An iMac ?
WazmeisterWazmeister Frets: 9615
edited March 2018 in Studio & Recording
Ok.
So, I'm still a complete 'haven't really got a clue' newbie into all this...
I'm trialing a couple of devices into Ableton/Logic/Garageband;
1.) Push 2
2.) Elektron Digitakt
3.) Teenage Engineering OP-1
Now, the first two recommend that you don't use a USB hub to connect them to the Mac;
...so, without a hub, how do you do it ? Is there a special user interface.
I love the Digitakt and OP-1, but I cant get the Digitakt to interface with the Mac...
I've got a NI Komplete Audio 6 but no idea how to integrate these.
Told you it was a daft question !
  • spark240spark240 Frets: 2092
    I use a hub with Mac mini no problem...
    Mac Mini M1
    Presonus Studio One V5
     https://twitter.com/spark240
    Reddit r/newmusicreview
  • GavRichListGavRichList Frets: 7215
    My iMac has three or 4 USB ports on it anyhow? But hubs work fine.
  • SporkySporky Frets: 28730
    edited March 2018
    There can be limitations with hubs. Firstly there's the potential for not having enough power in the bus, which is easily solved with powered  hubs, but there's also the 5-hub limit per chain . The motherboard probably has at least one onboard hub, the devices may contain one too.
    Normally that's ok, but in a weird setup you can exceed five pretty easily.
  • RandallFlaggRandallFlagg Frets: 13960
    I use a powered 4 port USB hub without problem into my iMac
  • wave100wave100 Frets: 150
    I use a 7 port powered hub into my Macbook Pro with no issues with 4 MIDI devices, a USB HDD, Cubase dongle and computer keyboard - my audio interface can't go via a hub though. Check the reviews for each unit, I'm led to believe some of the cheap ones can be a bit crap.
    You could try old fashioned 5 pin MIDI cables (MIDI OUT on soundcard to MIDI IN on Digitakt, MIDI THRU to MIDI IN on OP1)
    I imagine the push needs USB but I don't have one to check.
