theFB Jam - South (WaterRats) SetList
  • Tony, I stuck my name down for bass on Sweet home a while ago. I'm happy to pick another bass track as long as it's not too complicated.
  • peteripeteri Frets: 1283
    Quick question - I’m or the Axe III if it turns up, shall I bring my DXR10, or straight into the PA there?
  • TTonyTTony Frets: 27495
    Ahhh yes, added you in now.
  • mrkbmrkb Frets: 6809
    Yes I’ll do lead on the version of Come Together I’m not singing on.
    Karma......
    Ebay mark7777_1
    And I can’t sing on the first Honky Tonk woman version , I’m busy concentrating on the guitar.
    Karma......
    Ebay mark7777_1
    For the main set I suspect straight into a PA, but for jamming in the other rooms it helps to be self sufficient. I might bring a Atomic CLR for the AX8.
    Karma......
    Ebay mark7777_1
    Thanks I’ll bring the speaker then, will be interesting to compare
    I also vaguely recall saying I'd play the acoustic but on comfy, not that I've even looked at that yet
    Thanks - added you in for that.
    And  removed you from vox on the one you're playing guitar on
    Win one, lose one!
  • I’ll have a crack at the Lead on fortunate son.
    Dont worry about “Shot by both Sides”, I think it’s a great tune but maybe a little ‘left of centre’ for many.
  • Tone71Tone71 Frets: 625
    I`ll have a pop at lead on Come Together, either one or both.
    Don`t expect great things though!! :)
  • BroccoBrocco Frets: 88
    Happy to give the first solo on Come Together a try - will need a buddy though as it's harmonised. There is a good YT video from guitarlessons365.
    edited April 2018
    tell me which part from the first solo you want to play and I'll learn the other harmony part. I'll add a four bar intro thats played by the piano to lead into the harmonised solo bit.
    Karma......
    Ebay mark7777_1
  • MtBMtB Frets: 922
    @TTony - I don't think I've yet confirmed to you, but the bass line on Down at the Doctors is simple enough that I can handle it. Who's gonna play the harmonica and piano parts tho'? Any takers out there?
    edited April 2018
    @MtB ;;
    You mean you'll do bass & vocals instead of rhythm & vocals?
    Is that you @alnico?  Playing those parts on guitar...
  • AlnicoAlnico Frets: 4616
    edited April 2018
    TTony said:
    @MtB ;;;;
    I'm playing something over those bars which would normally have the Harmonica playing but I'm trying to make it contrast with the actual guitar solo which immediately follows it so it's not just one long solo.
    Is that ok?
    EDIT:
    If someone does want to cover that Harmonica section with an improvised solo of their own, which will naturally contrast with mine (which will be as close to the record as I can get it) that would work better and give more scope to more people. I don't want to take up both Solos if someone else wants to improvise over that first section?
  • MtBMtB Frets: 922
    edited April 2018
    Yes, I'll do bass and vocals @TTony ;
    @mrkb if ok with you I'll take the higher harmonic section of the first solo (from 6:20 in the guitarlessons365 video).
    Yep, that’s fine with me.
    Karma......
    Ebay mark7777_1
  • TADodgerTADodger Frets: 211
    Happy to try either harmonic for lead on come together Mk2 and lead on Fortunate Son Mk2.
