Removing pickup cover logos
I'm really not a fan of logos on pickups. Is there anything better than using something like the Halfords super fine finishing pads for removing them?
  • FunkfingersFunkfingers Frets: 14487
    The pad printed logo paint can be dissolved off.
  • steamabacussteamabacus Frets: 1266
    edited April 2018
    I don't like logos either.
    I've had success with isopropyl alcohol (IPA spray) in the past (plus some elbow grease with a cotton cloth)  but have also had ones where it wasn't quite enough and I had to use an abrasive pad. I don't like shiny guitars, or one shiny pickup on an old guitar, so this wasn't a problem.
  • lewismlewism Frets: 250
    If it’s printed onto a gloss bobbin (e.g. Seymour Duncan), some T-Cut or similar will polish it off pretty quickly, you’d just have to make sure you polish the whole surface to make sure it all matches.
  • bbill335bbill335 Frets: 1382
    I got the wilkinson foil logo off some pickups by getting a sharp blade under the foil, then rubbing with something abrasive.
