Would this concern you?
See photo...
  • StrangefanStrangefan Frets: 5844
    Nope....... <<<<<see response.
  • SlopeSoarerSlopeSoarer Frets: 845
    edited April 2018
    Good.
    Next question is it reasonable for it to be there on a new guitar (bought online)?
  • kaypeejaykaypeejay Frets: 777
    Good.
    I would say not. You should be able to return if within the cooling off period without any problem.  Before doing so, send pics to the supplier and do it quickly. Was there any damage to the package?
  • proggyproggy Frets: 5835
    I wouldn't accept that on a new guitar, I'd send it straight back.
    New guitar... No not a chance,:)
    No there was no damage in fact it was double boxed. The annoying thing is this is a replacement for one which had more problems!!
    I have sent photos and asked for their thoughts, part of me says it will be OK let it go but then it shouldn't be there.
    I'm not usually a serial moaner =)
  • Winny_PoohWinny_Pooh Frets: 7779
    DISCOUNT
  • robwrightrobwright Frets: 738
    edited April 2018
    Agree with @Winny_Pooh - that's worth a discount
    It’s only worth a discount if you can put up with the problem. I’d want a replacement.
    And why did I get a LOL for my first post?
  • carloscarlos Frets: 3451
    That would be more than enough to put an instrument in the b-stock section, so unacceptable for a new instrument. Send it back.
  • ICBMICBM Frets: 72486
    Yes it would concern me. There appears to be a slight separation of the wood grain, not just a depression in the surface. On a second hand/B-stock guitar I would probably look at having it repaired, just to stop moisture getting in. On a new guitar I would want a fairly heavy discount to not send it back, and then get it repaired.
    It's not a huge deal, and older guitars do get far worse than this, but I wouldn't start off with a new guitar in this condition if you can avoid it.
  • kjdowdkjdowd Frets: 852
    Agreed. I'm really not fussy about the odd ding, but I wouldn't accept that on a new guitar.
  • richardhomerrichardhomer Frets: 24834
    That definitely needs to go back....
    Cheers for the advice :)
