Are Boss pedals "old hat"?
  • 57Deluxe57Deluxe Frets: 7345
    edited April 2018
    My BOSS ME-5 gives me the most deliciously self absorbing lush UniVibe (custom programmed) anywhere...
    <Vintage BOSS Upgrades>
  • thecolourboxthecolourbox Frets: 9888
    If only they did a fuzz!
    soundcloud.com/thecolourbox-1
  • TeetonetalTeetonetal Frets: 7815
    Some people will say yes, some will say no.
    I've moved back to boss for some stuff, not for others. Base it on sound not brand
  • ICBMICBM Frets: 72667
    http://images.equipboard.com/uploads/item/image/5042/boss-fz-2-hyper-fuzz-xl.jpg
    Best fuzz ever. Basically a Shin-Ei FY-6/Univox Superfuzz circuit but with active EQ and a clean boost mode. (And the other usual Boss advantages.)
    There are also the FZ-3 and FZ-5, but I don't like those as much.
  • SamgbSamgb Frets: 774
    I spent a decent chunk of change on my MD-500 and sold all my other modulation. Thing of beauty to get lost in. I also like my Waza BD-2 as a kind of always on 'more' pedal.
    Then at the other end of the BOSS price range I also recently had someone give me a bog standard SD-1 which id never tried before and its pretty much my perfect OD.
    They make some good stuff and some stuff that i have no use for like everyone else.
  • TTBZTTBZ Frets: 2912
    edited April 2018
    I like Boss stuff. The switching is the best, I like having that big pad to stand on rather than a little 3pdt switch. I've only got one boss at the minute but will definitely get more. My overdrive is a Hardwire CM2 which has the same style of switch but true bypass instead - tbh might just get an SD1 as I'm pretty much dialling in the eq the same as a normal TS after all! Keen to try a Blues Driver as well.
    I wish they'd hurry up and do a Waza FZ2, it'll help push down used prices of the originals!
    But only the fz5 currently I believe which when I tried sounded awful sadly, the Akai £25 job I tried at the same time walked all over it.
    Which is a shame as every other boss I've tried sounded pretty good even with me playing it
    True, but the FZ-2 is not all that rare - although admittedly getting fairly expensive now.
    Behringer actually do a copy of it - the SF300 Super Fuzz - which is under £25 new... I've been thinking of getting one as a spare. But I should have bought it a few weeks ago when they were under £20!
  • dindudedindude Frets: 8540
    Kinda like a Nissan Qashqai - absolutely fine, but nothing to get excited about in the main. For every Boss pedal, I can think of many others I’d rather own. Only exception is for a straightforward digital delay the DD3 is still hard to beat.
  • tone1tone1 Frets: 5187
    I’m a recent Boss convert.... just need to try the overdrive side of things really but very happy with the DD-2 delay and Modulations...
  • LordOxygenLordOxygen Frets: 319
    edited April 2018
    When i was learning to play in the early 90s I had a mate who was massively spoilt by his parents. He never really bothered to learn properly but had a load of cool gear including a substantial boss pedal board, which at the age of 13 - 14 was the shizzle. They would have been analogue ones, chorus, distortion, flanger and a few others. Fast forward 20 years when I started playing again and I went out and bought several boss pedals just because I've always wanted some. The handful I have are great for hacking away at home I see no point in spending more and they're built like tanks compared to the ehx ones I've got.
    In conclusion I like Boss pedals a lot.
  • KeefyKeefy Frets: 2323
    I use two Boss analog delays, an original DM-3 and a modern DM-2w. As compact analog delays go, they're hard to beat.
    To me it's a different story with drives - for example there are plenty of distortions available these days, many of them inexpensive, that urinate all over the DS-1 from a great height.
    They're a good average pedal.
    I think everything they do has a better sounding equivalent from another manufacturer but for the most part they are ok, apart from their flanger anyway
  • AlexCAlexC Frets: 2396
    It’s unusual for a pro guitarist not to have at least one Boss on their board. Says it all really. Bottom line - they’re reliable.
  • SporkySporky Frets: 28734
    The DC-2 is still the finest chorus pedal ever made. Probably the finest chorus pedal that will ever be made.
    Tell me about it, could have picked one up for £30 in a shop sale once but didn't. Bugger!
  • I dig Boss pedals. I have their tuner and also the waza chorus and analog delay which are both super cool.
    people seem to knock their drives and distortion but I like them. I chose the (digital) DS1X over a Suhr Riot as the Boss just sounded better to me. I’ve been equally impressed with the OD1X which is really versatile.
  • JezWyndJezWynd Frets: 6118
    Agreed. The new digital drives are really impressive, not at all digital sounding, except that they give a clarity that analog can't achieve, esp at high distortion levels.
    Re the DC-2 (I agree, it's a wonderful chorus) the behringer clone was a good copy and has been superceded by a TC copy called 3rd Dimension which I've read also sounds identical to the original save for there's no stereo output (and it's more  flexible 'cos you can press multiple buttons simultaneously).
  • I never see much mention of the Harmonist PS-6, but it looks like it can do a lot of cool things,  check out the Killing in the Name Of solo at 5.15:
    https://youtu.be/CZYt8PJDCZs
    And craziness with an expression pedal:
    https://youtu.be/iVPf6AFu32g
    I need to check out this effect on the Katana.
  • GulliverGulliver Frets: 850
    they’re cheap and OK - like McDonald’s. In my youth, perfectly acceptable and wallet-friendly.
    These days, I prefer better burgers and better pedals, and have a wallet capable of allowing me to do so.
