Anyone made a headless neck?
axisusaxisus Frets: 28339
edited April 2018 in Making & Modding
I'm not sure how to tackle the head end in terms of shaping of the neck after the nut. I will be using an ABM locking headpiece like this. Any thoughts? Advice? seen any plans?
  • octatonicoctatonic Frets: 33804
    When I get back to the UK on Monday I will send you pictures of my Forshage Orion which uses the same headstock design, but a brief google for that make/model might help too.
  • SporkySporky Frets: 28464
    I always think they look a bit odd headless. How about having tentacles sprouting from it?
  • carloscarlos Frets: 3451
    I sold a headpiece like that one to @WezV so I'm sure he has a project going on using it.
  • axisusaxisus Frets: 28339
    Fab ta!
  • WezVWezV Frets: 16734
    Yeah, I will hopefully be doing one this year, but I have not thought about that but yet.    I am thinking I will still leave some kind of headstock transition from the main shaft... but just enough to let me know where I am at
  • ICBMICBM Frets: 72482
    No shaping whatever - simply make the neck taper go straight to the end block. Anything else looks ridiculous.
  • GizmoGizmo Frets: 1078
    I do like the way that skervesen do it for there headless models
    Totally pinching this for my current headless build.
    @Gizmo thanks, a very useful picture. I failed to find much showing the back with my search.
    Some sort of volute is probably useful so you know where the end of the neck is
    but it would make for a very fat neck, which doesn't suit the style.    They are a lot chunkier than the steinberger headpiece
    In that case it will have to be like in Gizmo's post above. It might be better with a shorter thick section though, from where it looks like the frets are.
    That’s what I was getting at in my first post
  • RolandRoland Frets: 8731
    edited April 2018
    Here’s a simple headless headpiece. It is made from a standard neck with the head cut off. A string retaining screw block sits inside the L bracket. The projecting semi-circle protects other band members from the perils of sharp string ends.
    The idea behind the project was to remove the weight of the head, and re-balance the guitar. It didn’t get any further than a prototype because I couldn’t find, or make, body end tuners which I liked.
    What type of tuners will you use?
    I thought you meant shaping between the nut (or zero fret) and the string clamp. Sorry, my mistake!
    Either way, keep it as minimalist as possible, anything else looks daft without a proper headstock.
    Well I have not designed it yet... but many modern headless guitars have an obvious transition into the head block and that is what I will replicate to some degree.
      To me it does feel better than the steinberger style, and I think it allows a more stable mounting
    No, not really. Your hand never touches the headstock when playing unless you're tuning. Really. I've been playing my headless for 5+ years and I've never slid off the neck or anything close to it.
  • sweepysweepy Frets: 4189
    Steinberger necks are actually v v chubby, easily as much of a handful as 50’s Les Pauls, it’s the Spirits etc that have slimmer neck profiles
    @axisus ;
    BTW, that headpiece needs either a zero fret with lots of pressure on it (so a sharp string break angle) or a nut. It doesn't hold strings at a consistent separation very well. I think nut is a better option being easier to swap than a zero fret that will have grooves dug into it very soon. I believe @octatonic 's Orion is built like this.
