Squier VI bass
Theres loads of stuff wrong with this ‘guitar’ that can be sorted by doing mods. Has anyone one here done them by themselves and how costly is it otherwise I may have to just give up on the idea and move it on
  • I had one for quite a long time.
    The only thing I did to mine was putting heavier strings on (labella make a set designed for the Fender VI) then I adjusted the truss, bridge & nut to suit. Simple & certainly not something I haven't done to virtually every guitar I've owned.
    I disagree that there's anything "wrong" with this guitar. It's just different & in a world where PRS have started making £2300 Strat copies different can be a VERY good thing.
  • Moe_ZambeekMoe_Zambeek Frets: 3423
    I had one that was a bit meh to begin with, @ICBM did some tweaks and made it a lot better without needing new bridge or saddles etc (the usual internet received wisdom) . I still found it a bit floppy on the low e and ultimately decided what I really wanted was a baritone guitar rather than a 6 string short-scale bass.
    I enjoyed it, especially with fuzz, but haven’t missed it since it’s gone. For me, the Reverend Descent was closer to what I wanted (but ultimately I havent bought one of those yet either!).
  • FunkfingersFunkfingers Frets: 14496
    Lord Seven will probably have something to contribute on this topic.
  • lasermonkeylasermonkey Frets: 1940
    A Staytrem bridge is well worth fitting, as the one they make for the VI is a bit longer, allowing accurate intonation. A better set of strings will also help, and Axion/Newtone does a set which isn't stupidly expensive.
    My wife asked me to stop singing Wonderwall.
    I said maybe.....
  • Cheers, thanks a lot for these tips, I really like the idea of it and would love to get it sorted. It seems as though the only way I can get the low E sounding less rattley is to set the action really high but the saddle screw ends up creating a buzz as it sits so close to the point where the string enters the saddle
