Hydrogen
  • crunchman said:
    Maybe we should reduce our carbon footprint by just not letting Richard Hammond anywhere near any vehicles?
    Not just Hammond:
    https://www.independent.co.uk/arts-entertainment/tv/news/top-gear-new-series-when-what-date-car-fire-eddie-jordan-chris-harris-monte-carlo-rally-a8192656.html
    I think that was the episode where Harris killed two Volvo 4 x 4s as well.
    Ah yeah! good point  =)
  • JalapenoJalapeno Frets: 6399
    Instead of the Hindenberg, a re-issue of Led Zeppelin 2 could have a head-on crash of two hydrogen powered cars ;)
    Feedback
  • mr-macmr-mac Frets: 200
    One wee thing about hydrogen... Yous seen how much electric it takes to extract and pressurise hydrogen??????
  • I shudder to think how much more "greenhouse effect" all that water vapour will make. That being said Lithium is also a finite resource.
    Err... None?
  • fandangofandango Frets: 2204
    edited April 2018
    A mash up of Led Zep and The Cars? Cool. If only I could find one ....
  • ICBMICBM Frets: 72666
    It doesn't matter as long as the electricity is generated from renewables. That's energy which is already present in the environment and just needs to be tapped.
    crunchman said:
    I think it's a better alternative than battery powered cars.
    Equipping a few thousand filling stations to deliver hydrogen will be a lot cheaper than installing millions of electric car charging points and massive upgrades to the grid.
    The charging time for electric cars is still an issue as well.  If they get bigger batteries to get more range, then it will become a bigger issue - unless they put in really fast charging points, which will require even more upgrades to the electricity infrastructure.
    Hydrogen is a good way to store intermittent electricity from renewables as well.  When there is a surplus, you separate the hydrogen from sea water using electrolysis.  Countries with lots of spare renewable resources
    like Scotland.
    Scotland has the highest potential for renewable energy generation per head of population in Europe, from something I read a while back. It's certainly wet and windy enough, and with huge tides and wave energy from the Atlantic.
    It saddens me that the Scottish government hasn't been encouraging investment in this much more than they have, instead of relying on the oil industry. It would be fantastic if the UK could become self-sufficient in hydrogen cell energy.
  • thebreezethebreeze Frets: 2809
    HAL9000 said:
    It is also far more volatile than petrol and holds less energy for a given volume.
    Ah, I noticed in the cutaway diagrams for the RiverSimple Rasa that the fuel tank occupied pretty much all of the available boot space.
    I think they're developing a 4 seater and a van now
  • RockerRocker Frets: 4993
    Rather than generate more and more electricity, reduce demand by the use of more insulation in houses and drive cars, with a sole occupant, less than we do now.
    Nil Satis Nisi Optimum
  • WezVWezV Frets: 16793
    edited April 2018
    Or, do those things... and find ways to provide cleaner fuel
    Doesnt have to be either/or
    Why wait to charge a car? Why not exchange your empty batteries for full ones?
  • vasselmeyervasselmeyer Frets: 3674
    Because every manufacturer has a different format . Unless there is an industry standard then you need to charge them or get a specific Ford/Toyota//Volkswagen battery at your charging location.
  • BucketBucket Frets: 7751
    I would 100% have a fuel cell car if I could.
    Because they are large and heavy, and not easy to get in and out of a car.
  • hobbiohobbio Frets: 3440
    But if batteries were standardised and a standard mechanism could be designed for an automated drive in drive out swap it could be done in seconds.
    electric proddy probe machine
    My trading feedback thread
  • Axe_meisterAxe_meister Frets: 4659
    This was tried in Israel. The ex CTO of SAP started a company call better world. Alas it went bust. A hard one to do. Technically fairly easy. Lift car, drop battery, insert new battery, lower car drive off.
    But it will mean a standard battery across all manufacturers, forcing a standard layout. Will also mean a small car will have massive range and a large heavy car much smaller range.
    Surely if it was standardised there could be a way that a large and heavy car could be fitted with a second battery? In the same way that bigger cars tend to have bigger fuel tanks.
  • SporkySporky Frets: 28732
    If you have a look at how the Teslas and the forthcoming i-Pace are built (along with many others) the batteries are fitted into the floorpan - no way you can simply pop them out.
    Building a car that had a swappable battery would mean massive compromises in packaging. Either it's much bigger than with an integrated battery, or there's a lot less space inside, or the centre of gravity is far too high for safe handling.
    A car subscription is probably more sensible - drive one car in and it goes on charge; you leave in an identical one that's just finished charging. But that means moving away from the current concept of car ownership.
    It probably isn't that far off though - I can definitely see a future without much car ownership.
    It may mean fewer cars on the road and fewer cars being built, too - which could be positive for the environment.
    I think you're right that some kind of subscription model in terms of cities and for typical car use will come. Most cars sit in one spot doing nothing for 95% of their time.
    However, further out from cities and suburbs you tend to get more specialist uses and there will still be vehicle ownership in one form or another.
    Ah - sorry, I meant "more sensible than swapping batteries".
    I know there's been a fair shift towards leasing cars rather than actually owning them, but I think subscription will be a slow grower, and I agree it'll be more appropriate in towns and cities.
