2 Cheap & Cheerful Pedals FS* WITHDRAWN
What we have here ladies and gents are three completely non prestigious pedals. However, if you are unconcerned about branding then they all work, do the job and sound great. All prices include p&p. Have original boxes although the Morpher doesn’t have the little instruction booklet. Still, I’m sure you can work it out. The two Donners only take a 9v power supply, but the Danelectro will also take a 9v battery.
Danelectro Fab Overdrive - smooth overdrive. Great sustain. £10.
Donner Yellow Fall Analogue Delay - very robust. Pretend you’re The Edge or a rockabilly twang merchant. £15 *Withdrawn
Donner Morpher Distortion - again, robust build. A Suhr Riot Clone, apparently. £15
other two still up for grabs.
