Borrow it and see if you like it...
Make sure the High/Low power switch is set to High, they sound much better like that, and pay no attention to where it says '4' on the impedance selector - that's one of the most stupid pieces of mislabelling on any amp - it's 16 ohms or 8 ohms only on the head. (Combos are the other way round, 8 or 4 ohms only.)
And hope it blows up with the 30 days, if it's going to...
Having worked on several Engls, I wouldn't own one. Too many design faults, difficult to work on due to construction choices, expensive specialist parts, and poor customer service from Engl.
I agree with the 900s not having the sheer volume of an 800 too, but that may well also be a good thing here.
I wondered how similar it is to the jcm900 mkiii???
You really just need to try these amps for yourself - you will never know what's going to suit you otherwise.
