New guitar questions. Do the 80s count as vintage?
StuckfastStuckfast Frets: 2412
... the 1880s, that is?
https://postimg.cc/gallery/gl4oesf0/
So... many years ago I was in one of the acoustic shops in Denmark Street and tried out a pre-war Washburn parlour guitar. I thought it was fantastic, but they wanted £4k for it and I didn't have £4k.
Then last week I spotted this on eBay -- listed as a Lyon and Healy parlour model from before 1887 (something to do with the shape of the neck joint apparently). Happily it wasn't £4k and now it's mine. Tis a dinky little thing with the most V-shaped neck ever!
It sounds great although the existing strings are a bit knackered and I don't have a spare set here. Seller says that he uses conventional but light steel strings, is that OK or should I go for low tension ones? There's a crack running along the bridge, but I'm told this is stable and has been that way for years. Most of the strings intonate a bit sharp at the 12th but I'm hoping that is partly the ancient strings. Action is high-ish but playable -- about 4.5mm at the 12th on the low E -- and of course there is no truss rod. Wondering whether it might be worth thinking about a neck reset at some point.
  • DiscoStuDiscoStu Frets: 5467
    That's cool. I can't imagine there are many folk on here with a 19th century guitar. Good luck getting it set up and looking forward to a sound clip or two.
  • DulcetJonesDulcetJones Frets: 515
    Cool.  As for 80's and "vintage" goes, I was listening to a pop radio station (by accident) that called itself an oldies station.  They were playing Duran Duran and other 80's hits.  I feel old now.
  • jimmyguitarjimmyguitar Frets: 2467
    Lovely guitar! I think the bridge does need looking at just to be safe. While you’re at it just get them to advise re neck set and string guage. It’s worth getting it back to it’s best.
  • earwighoneyearwighoney Frets: 3494
    Yep, it seems a neck reset is on the cards.
    As for strings, I think if my memory serves me correctly some of the guys from the Martin forum like Thomastik for their pre 1920's acoustic guitars. Closer to home the Newtone Heritage strings in 10-47 should work as well.
    Thanks all, I shall take it to a tame luthier and see what he says. Any idea what the going rate for a neck reset is, if needed?
  • GarthyGarthy Frets: 2268
    I can see the arguement for calling 80s Jacksons, Charvels, Kramers and ESPs vintage, but not Fenders, Gibson or PRS.
    About £300 my neck of the woods.
    Ouch!
    Let's hope one is not required.
    Thinking a bit more about this...
    The intonation is fine on the strings with the thinnest cores (high E and wound G) and progressively worse on the others, which is hardly surprising given that it's a short scale guitar and the saddle appears to be a single piece of fretwire. Would it be sacrilege to simply replace the original bridge with a modern compensated one? The intonation bothers me more than the high-ish action.
  • brooombrooom Frets: 1174
    That is a really cool find. I love the neck shape, that's V taken to the extreme. Definitely worth bringing it back into a state of playability. Let us know how it works out.
  • ICBMICBM Frets: 72321
    If the saddle is simply fretwire, could you shave off enough of the bridge to remove the slot for it - which would also help the action - and re-slot it with compensation? That would leave the original bridge on the guitar.
    I'm a bit doubtful about modifying the original bridge to that extent -- it would take quite a bit of shaving to remove the slot and given that the bridge is already cracked I'd worry about damaging it further. I think it might be better to try to remove the original bridge intact so that any future owner could put it back if they so wished.
    If you think you can get it off intact and without damaging the guitar that's probably the best solution, yes. Just get a new bridge made as close to the original as possible but lower and with a compensated saddle.
    It does look as if the bridge might have been re-fixed at some point anyway. We'll see.
  • CorvusCorvus Frets: 2925
    Nice find!
    Is the neck bowing, that might account for some of the high action.
    Looks like that bridge has already been off at some point. Remove/replace will be relatively easy, with the finish being slightly gone around it.
    I'm slowly working through an old acoustic, no truss rod, I've removed the board, trued the neck and put in a square carbon fibre tube with titanium rod epoxied inside that. Making a bridge next, it had a similar but much worse split, was all butchered to hell.
    I haven't taken the strings off yet, but with the strings on the relief is pretty much spot on as far as I can see. If you fret at the first and last frets there is a hair's breadth of clearance in the middle.
  • HattigolHattigol Frets: 8189
    It's 33 years since Live Aid.
    I'll just leave that thought with you.
    "Anybody can play. The note is only 20%. The attitude of the motherf*cker who plays it is  80%" - Miles Davis
    Hmmm. Took it to the guitar repair man this morning. He reckons a neck reset is definitely needed, but hopes that it should be fairly straightforward.
    The question that hasn't yet been answered is whether the split in the bridge runs down into the top and the brace behind it. If that's the case I think I might have to have words with the eBay seller, as it wasn't mentioned at all in the listing and wasn't visible on the photos.
    Never say never but in my experience it’s always just been on the wood of the bridge running along the string holes. I’ve had a gibson and an old martin with that same issue.
    It should definitely have been mentioned by the seller though, as should the need for a reset.
    When buying old acoustics I always assume they’ll need a reset and some work and factor that into the price as it’s nearly always required. It’s worth doing though, it’ll be a lovely guitar to own once it’s been fettled!
