WTB: Neck Humbucker
  • ElwoodElwood Frets: 454
    Still looking and cash waiting :)
  • deloreandelorean Frets: 224
    Just a suggestion, but I can definitely recommend the Bareknuckle VHII for a balanced treb/mid and tight low end response.
    I play 80s hair rock, and the VHII works beautifully in the bridges of my superstrats
    @delorean Thanks for the recommendation.
    I've also seen that an SD Alnico 2 might do the job, I'll add them to the list.
  • TeyeplayerTeyeplayer Frets: 3223
    Got an sd 59, chrome covered that I’m about to swap out of a guitar. Must be honest haven’t checked if it’s 2 or 4 wires or the colours under the hood but may be of use to you. Pop me a pm if your interested.
  • FunkfingersFunkfingers Frets: 14483
    Elwood said:
    cash waiting :)
    Aye but how much?
    I've got a few hundred quid for the neck pickup out of Jimmy Page's early LP. :)
    Anything else would depend on make, model and condition. @Funkfingers ; Have you got something that fits the bill?
  • If you absolutely cannot find anything else and don't mind going all black, then have a look at this - http://thefretboard.co.uk/discussion/129819/fs-dimarzio-the-breed-neck-humbucker-40-posted#latest
    Elwood said:
    Funkfingers.
    Hello. Yes. Apologies for tardy reply. I changed my notification settings.
    Seymour Duncan OEM short lugs SH-1N '59, cream/black, nickel plated screws, new typeface pad-printed logo. Never been soldered into anything. No packaging. The pickup was sent to my local Charvel dealership in error. (He required an STK-S4N for a warranty repair on a hardtail San Dimas.) I have spare pickup boxes for shipping.
    Cheers funkfungers  - is the tip coil or bottom the zebra?
    Screw coil, cream. Slug coil, black.
    Thanks a lot Funkfingers but i've had a couple of '59 owners tell me they are a bit scoped & arn't quite what i'm after. I've updated the thread.
    edited May 2018
    No worries. I have a probable outlet for the pickup locally.
    FWIIW, the midrange scoop can be cured by the simple expedient of changing the bar magnet from A5 to A4.
    Is it easy to change a magnet or Is Not a job for Ash at Oil City?
  • AlegreeAlegree Frets: 665
    Pretty much as easy as humbucker mods come if it's uncovered.
    And, yet, still possible to get wrong. ;)
    Elwood said:
    i've had a couple of '59 owners tell me they are a bit scooped
    Well, it does purport to replicate a pickup design originally intended to suit Jazz guitars. It is supposed to have the metal cover on it and the polepiece screws are supposed to be adjusted upwards to compensate for output imbalances from string to string.
    I would not be surprised if at least one of your '59N owner friends has all six polepiece screws set almost as low as they will go and with the slots all aligned perpendicular to the string path.
  • Jack_Jack_ Frets: 3175
    edited May 2018
    Is a DiMarzio D Activator (DP219 - Neck) of any interest? Description matches your frequency requirements. Kinda fits with the Evo and S1 as well.
    Bump
    Bump
  • MattayusMattayus Frets: 122
    Got a Duncan Distortion neck I'm thinking of getting rid of if it's of any interest to you?
