Basket Case - Key Shifting
monquixotemonquixote Frets: 17669
in Technique tFB Trader
OK question 2!
Same setup dep gig, many songs, minimal time to practice with the band.
One of the songs I've got to learn is Basketcase. Not a hard song by any means, but the chord changes are too fast to read it off a cheat sheet so I need to learn it properly and the original is in Eb whereas they are doing it in E which makes it hard for me to learn it along with the track.
So does anyone know of a backing track in E or an easy way to pitch shift it?
  • mike_lmike_l Frets: 5700
    Tascam guitar trainer CD player which has a facility to alter the cd's tuning (Eb - E is easy, I've done it with my Thin Lizzy CD's). And tempo likewise.
  • monquixotemonquixote Frets: 17669
    Not looking to drop any ££ so ideally want something software based.
    I suppose I could use audacity if I obtained a copy of the track somewhere, but it tends to result in nasty artifacts.
    I can loan you the CD if yo want.
  • You used to be able to do that in Audacity for PC. Can't remember off the top of my head exactly how, though. I'm sure if you download it there will be guides on Google somewhere.
  • GrunfeldGrunfeld Frets: 4046
    Transcribe can do that no problem.  And slow it down for you too in the new key.
  • bobblehatbobblehat Frets: 544
    Couldn't you just detune half a step to play along to it ?
    Its been a long day and I'm tired so I could be talking complete bollocks.
    Yes I certainly could, but I'm doing stuff in setlist order so it's easier to shift it.
    That makes sense , easier to remember them if you learn them in order.
    The detune option seemed so obvious I started to doubt myself
  • johnnyurqjohnnyurq Frets: 1368
    What about a MIDI file which is easy to shift key quickly.
    I have done that with success a few times.
    When we covered it I used a digital capo on the VG-99 or a Variax FX combo.
  • DulcetJonesDulcetJones Frets: 515
    If you can find a copy of it scored for Powertab Editor, or one of the other programs like it you can do it easily.
    The chord progression is
    E5 B5 C#5 G#5 A5 E5 B5 B5 (repeat)
    then
    A5 B5 E5 E5 (repeat)
    then
    A5 B5 E5* D5* C#5
    1 bar each except * 2 beat on each  As played on the album, where the guitar was tuned to Eb.
    Hope that helps
    There's a clip on youtube of one of my bands playing it in E (although it's before I joined).
    @Clare_bear is there....it was the bands first gig I believe.
    http://www.youtube.com/watch?v=OfQV5owVsZ8
